Activity Forums Blackmagic Design Strange Problem with 6.4 windows
  • Strange Problem with 6.4 windows
    Posted by Yasser Amin on August 8, 2007 at 12:48 pm
    Hi
    I just installed CS3 Production Premium and new 6.4 windows driver, but can’t fined the preset of decklink in premiere 3, what is the problem
    PS: I installed the CS3 Production Premium in another hard disk not in the main program files of system disk, is it the problem, and if how I can install decklink driver with this case
    thanks
    Yasser Amin replied 19 years, 1 month ago 2 Members · 2 Replies
  • Stewart Mayer
    August 8, 2007 at 3:37 pm
    On the adobe website for premiere pro 2.0, under the updates section, you can find instructions for installing the canon hdv presets. I think all of the presets use the same installation method (certain files in certain folders). If you use the same installation instructions there, but substitute the appropriate files and folders for the decklink drivers I think the presets will probably show up. I had to do this in some CS3 betas and it worked.
    stew
  • Yasser Amin
    August 11, 2007 at 12:20 pm
    Hi stewart
    thanks for replay, I solved the problem by reinstall CS3 in c:\programs files\
