Activity Forums Adobe After Effects strange problem – AE combined Pro
  • strange problem – AE combined Pro
    Posted by Nils Palmen on May 15, 2005 at 12:49 am
    okay – i exported a file from premiere pro. this file is edited on music. i imported it than in AE. added some effects. exported it. imported in Pro . . . and now it looks like the file is speeded up a bit. it doesn’t fit anymore. anyone know what might be the prob?.
    tnx. n.
    Nils Palmen replied 21 years, 3 months ago 2 Members · 2 Replies
  • Andrew Kramer
    May 15, 2005 at 7:17 am
    Make sure your frame rate interpretation is correct (equal to source) then make sure your in and out points are not misplaced.
    Why not import your project directly into AE it maintains all the setting correctly for you.
    Good Luck
    Andrew
  • Nils Palmen
    May 15, 2005 at 10:07 am
    okay … something happend although i still do not completely understand what went wrong. The movie file i exported in AE was 25 frame rate – but the default setting in the ‘make movie setting area’ … i switched this one to the custom setting area and set it also on 25 frame rate. exported this file – imported it back to Pro – and now it fit’s .. strange strange 🙂
    tnx man!
