Activity Forums Apple Final Cut Pro Legacy strange pixel shift in timeline
  • strange pixel shift in timeline
    Posted by Vince Gaffney on May 23, 2007 at 10:34 pm
    I’m getting a pixel shift when I add a perspective effective to a clip. the footage was shot HDV with a redrock micro, captured to 10 bit uncompressed sd and needs to be rotated 180 degrees. it looks fine in the viewer, canvas and client monitor. when i drop it in the timeline, the entire frame then seems to shift down a pixel or so and displays what looks like interlace artifacts. deinterlace cleans it up bit, but it’s not good enough quality. changing the field order didn’t work either. any ideas.
    thanks,
    vince
    Vince Gaffney replied 19 years, 3 months ago 3 Members · 3 Replies
  • Ben Insler
    May 24, 2007 at 3:08 am
    When you say changing the field order, do you mean the Shift Fields filter? If not, see if that works for you.
    -Ben
  • Jeremy Garchow
    May 24, 2007 at 3:22 am
    Did you render this?
  • Vince Gaffney
    May 24, 2007 at 1:35 pm
    i rendered it and messed with all types of filters. i finally just exported it to Combustion, rotated it and reimported it. it’s perfect that way, but very cumbersome.
    vince
