Activity Forums Adobe Premiere Pro Strange parameters noted in AME-log / CS5
  • Strange parameters noted in AME-log / CS5
    Posted by Ninetto Makavejev on July 13, 2011 at 4:32 pm
    Hello,
    I am using CS5 and a Blackmagic Decklink card, editing uncompressed 10-bit YUV video captured via DigiBeta.
    I am using the Blackmagic Pre-sets for 10-bit 4:3 YUV sequences.
    The export seems to go fine, and the resulting export file which is using the exact same parameters as the sequence (10-bit YUV) seems also OK, but when I open the log in AME I see a line which bothers me.
    Using Preset “PAL 10 bit YUV 4×3” under “Video” is the following info:
    “0x0 -1 #IND, Prgressive”
    But neither the original file nor the export is progressive?!
    What is this supposed to mean?
    thanks and
    best regards, ninetto m.
    Ninetto Makavejev replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
