Activity Forums Adobe Premiere Pro Strange multiple bin issue
  • Strange multiple bin issue
    Posted by Peter Curran on July 20, 2016 at 4:35 pm
    I’m having this very strange thing happen when I open a new bin. The first time i open a new bin, its fine. When I open a second bin it creates 2 new tabs. When I open a 3rd bin it creates 4 new tabs. When I open a 4th bin it creates 8 new tabs etc etc.
    Here is a video to better demonstrate what I mean:
    https://vimeo.com/175573422/33ead704f7
    Has anyone had this issue before?
    I’m running cc2015.3 on an iMac Retina 5K, 27-inch, Yosemite 10.10.5
    Peter
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Duke Sweden replied 10 years, 1 month ago 6 Members · 5 Replies
  • Kevin Eslinger
    July 20, 2016 at 8:16 pm
    Same problem here… sounds like a bug with cc2015.3 Very annoying!
  • Chris Hall
    July 22, 2016 at 10:27 am
    I’m getting this too. Very annoying when I open a bin in a new tab and have to close 15 extra tabs that are created!
    Only started happening with cc2015.3. Is anyone using cc2015.3 and not having this issue? Could it be related to the operating system? I’m using mac os 10.10.5 like OP.
    Seems strange that this obvious bug didn’t get picked up.
    Chris
    cc2015.3, Mac Pro OS 10.10.5
  • Chris Hall
    August 1, 2016 at 3:47 pm
    The best workaround seems to be by using ‘open in new window’ and then manually dragging the window to form a new tab.
  • Yonatan Lehman
    August 9, 2016 at 6:57 pm
    The problem still exists in 2015.4 which I downloaded today (on Windows 10)
    I thought I could get around it using the existing keyboard shortcut panels/project panel/delete (backspace) but it doesn’t do anything so maybe it doesn’t work on a bin panel – only on a project panel (isn’t that the same as the top level bin ?)
    my 1st day or premier pro after 10 years of Avid….
  • Duke Sweden
    August 10, 2016 at 1:26 am
    I reported this weeks ago. It gets difficult to keep things straight as it is with my simple projects. I can imagine what a pain it must be for you all.
