Activity Forums Apple Final Cut Pro Legacy Strange Mini-DV pixellation issue – Please help!
  • Strange Mini-DV pixellation issue – Please help!
    Posted by Samah Bennett on April 23, 2009 at 5:13 am
    I am having a very strange pixellation issue when i digitize footage from a Panasonic mini-DV tape.
    here’s a screen grab:
    https://www.samahcinema.com/showpixellation.png
    As you can see the resolution looks really low. But I don’t see how that could be it, as it was captured Firewire. I also understand that it was shot in a very low light situation, but that would just create more noise right? This pixellation makes no sense to me. Please take a look above… I could really use some help as I have the client coming over tomorrow.
    Many thanks…
    Samah
    Samah Bennett replied 17 years, 5 months ago 4 Members · 5 Replies
  • Chris Borjis
    April 23, 2009 at 5:23 am
    thats a typical problem with full RED spectrum in DV video.
    Pure Red suffers the worst.
    the only option to get around that if it seems to play ok
    from the deck to the monitor is to capture it as ProRes over firewire.
  • Samah Bennett
    April 23, 2009 at 5:44 am
    Hmm… I have a mini-DV tape and a mini-DV deck and camera- capturing as ProRes requires HDV does it not?
  • Michael Gissing
    April 23, 2009 at 7:13 am
    That sort of pixelation in red is fairly typical of DV. I use Nattress chroma smoothing and sharpen plugin to clean that up. It won’t be perfect but it will help a lot.
    Also a bit of 3 WAY CC will help, particulalry reducing the saturation as well as pulling the balance away from red.
  • Rafael Amador
    April 23, 2009 at 8:59 am
    Absolutely. The DV pixelation is much more noticeable in a saturated red.
    As Michael wisely points, the “Nattress Chroma Smooth/Sharpen” and a 422 codec in your sequence will help with the pixelation.
    You may end up using that filter for all your DV footage. Even if doesn’t shows such a pixelation.
    rafael
    http://www.nagavideo.com
  • Samah Bennett
    April 25, 2009 at 12:41 am
    Thanks everyone for your feedback. I truly appreciate your time and thought.
    s.
