Activity Forums Maxon Cinema 4D strange material runover
  • strange material runover
    Posted by Jason Stirret on December 25, 2010 at 6:48 am
    So, I’m making a watch gear and have the base and outer teeth brass and the center is stainless steel. Only the brass material is spilling into the stainless (as you can see); they are separate objects. You can see the stainless showing though in the lower areas; problem is that I don’t want any brass showing in the top teeth or pin at all.
    Any ideas?
    Brian Jones replied 15 years, 8 months ago 2 Members · 5 Replies
  • Brian Jones
    December 25, 2010 at 4:54 pm
    can you post it?
  • Jason Stirret
    December 27, 2010 at 4:30 am
    I did…are you not seeing it? Perhaps I should post in another format? I think it’s a jpeg.
  • Brian Jones
    December 27, 2010 at 5:39 am
    sorry, can you post the file (or the part with the problem), I don’t have enough info other than to say so much depends on how it’s constructed that it’s easier to just see the file
  • Jason Stirret
    December 28, 2010 at 1:48 am
    well I could post but I figured out the problem. WOW! Talk about a brain fart, in order to set up for uv-map I duplicated a hypernurbs and forgot to turn rendering off for my back-up…dang.
    Thanks for your help at any rate!
  • Brian Jones
    December 28, 2010 at 3:40 am
    yeah, it looked funky enough I thought I wan’t going to be able to tell unless I saw the scene but it’s a good reminder for the ‘two objects in one space’ look
