Activity Forums Apple Final Cut Pro Legacy Strange Keyboard Phenomena on SnowLeopard
  • Strange Keyboard Phenomena on SnowLeopard
    Posted by Karim Daire on April 23, 2010 at 4:11 pm
    I recently upgraded to Snowleopard and FC Studio 3 and ever since I experience irregular problems with my keyboard settings in Final Cut.
    I don’t see a scheme there…. sometimes when I load Final Cut the Keyboard setup is changed, when I try to correct it Final Cut tells me its english, not german keyboard layout(I am from germany) before I can readjust my key settings. But other programs don’t have this problem.
    Also if I restart Final Cut… same problem. If I reboot the system I get correct settings again.
    I tried trashing prefs etc. but the problem keeps reappearing.
    Any hints or similar experiences since Snowleopard upgrades?
    Oh yeah…. I am working with a Macbook Pro.
    Karim
    Scott Sheriff replied 16 years, 5 months ago 2 Members · 3 Replies
  • Scott Sheriff
    April 23, 2010 at 6:11 pm
    Did you do a clean install of the OS and FCP, or just upgrade?
    Do a search on this forum under ‘clean install’.
    Scott Sheriff
    Director
    SST Digital Media
    https://www.sstdigitalmedia.com
  • Karim Daire
    April 25, 2010 at 5:17 am
    Hi Scott,
    no, both OS and FCStudio are upgrade installs.
    Can I install the Updates without having the previous installs before on a Macbook, I know that FCStudio will work but especially wonder about the OS 10.7 Update?
    Thanks for your help,
    Karim
    -Karim-
  • Scott Sheriff
    April 25, 2010 at 9:31 am
    That is most likely the problem.
    I know Apple says you can upgrade, but in the real world it just ain’t so.
    Treat both the OS, and FCP as a fresh install. As long as you have a valid ser# for FCP your good. The whole thing is on the upgrade discs.
    I would suggest you do a search in this forum using ‘clean install’, and do a bit of reading first. It will save you a lot of headaches.
    Good luck with that.
    Scott Sheriff
    Director
    SST Digital Media
