Activity Forums Apple Final Cut Pro Legacy Strange jumping problem
  • Strange jumping problem
    Posted by Roli Rivelino on May 23, 2011 at 10:55 am
    I’m working on a sequence whereby in the middle of it I’ve put a timelapsed clock that I bought online. The sequence is a DV square pixel 4:3 timeline and the clip is 1080.
    I needed to get the time to go from 10 till 2 and needed to break it into 2 clips for this.
    I’ve repositioned the clips so that the clock face is centralised and takes up most of the screen.
    The problem is that even though there are exactly the same motion values, they both have the same centre values and sizes. There is a very small jump between the clips and the second one appears to be slightly higher than the first.
    I’ve checked and re-checked and everything looks fine, any ideas?
    https://www.rolirivelino.com/
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Tom Matthies replied 15 years, 4 months ago 3 Members · 6 Replies
  • Everest Mokaeff
    May 23, 2011 at 1:36 pm
    Haven’t you seen a green line? I suspect you watch it on playback without rendering out. Try to render a trouble-maker.
    Free-lance fcp editor in Moscow
    http://www.mokaeff.com
  • Roli Rivelino
    May 23, 2011 at 3:27 pm
    No, no green line and I have watched before rendering out. What do you mean by rendering a trouble maker?
    many thanks
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Everest Mokaeff
    May 23, 2011 at 3:56 pm
    I meant preview mode that’s what happens when you add SD to HD sequence. Render SD segment and check out result.
  • Tom Matthies
    May 23, 2011 at 8:18 pm
    You don’t say what format your time line is, but the clip is HD. Do you have an extra (or none) Shift Fields filter on one of the clips?
    Tom
    E=MC2+/-2db
  • Roli Rivelino
    May 23, 2011 at 11:23 pm
    The clip is dvPAL and the clips are part of the same master clip, pretty sure those filters aren’t on either.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Tom Matthies
    May 24, 2011 at 7:09 pm
    In your original post, you say that the clip is “1080”. Is it an HD clip? If so, using it in a SD timeline should require the “Shift Fields” filter since the clip would be upper field first. I believe this applies to PAL as well as NTSC, but I’m not certain this is the case. Worth checking.
    E=MC2+/-2db
