Activity Forums Apple Final Cut Pro Legacy strange jerky blur
  • strange jerky blur
    Posted by James Wright on June 30, 2009 at 3:38 pm
    This only occurs after burning a dvd, having been through compressor and DVDSP, but i thought it made sense posting where it all starts.
    bassically, ive exported my video from FCP as a quicktime movie using current settings ( 720×576 using anamorphic 16:9 and quicktime video settings set to DVCPRO50 -Pal)
    Once thats done, the quicktime/FCP file is sent to Compressor where Dolby Auto is used in conjunction with a custom setting of
    MPEG 2 – m2v Extention – Pal – 16:9 – Top First Field Dominance –
    Two pass VBR best – Average bit rate 7.6 – Maximum 8.9 – motion estimation at best
    Gop Structure set to IBBP closed size 12
    This is then imported to DVDSP and subsequently burnt. When playing on TV’s (and only tvs mind) their is a slight juddery blur to movement, its not interlacing as far as i can see but is still VERY offputting.
    Any thoughts
    Thank you for taking time to read this.
    James Wright replied 16 years, 10 months ago 2 Members · 4 Replies
  • David Roth weiss
    June 30, 2009 at 4:24 pm
    You are most likely pushing the available overhead of your set-top player because you raised the bitrate of the preset in Compressor.
    Before automatically upping the bitrate, encode using the preset as is, then adjust if you feel you the need, but don’t start off by pushing the envelope right out of the gate.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • James Wright
    June 30, 2009 at 4:28 pm
    So what bit rate would you suggest?
    Would dropping the average bit rate to 6 and the maximum to 7 be more appropriate?
  • David Roth weiss
    June 30, 2009 at 4:40 pm
    The preset in Compressor comes at 6.2 and 7.7 max I believe. Try that first and then move on if necessary.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • James Wright
    July 2, 2009 at 2:28 pm
    Right i reduced the compressor, as suggested to a lower Mbps
    i set it to:
    average bit rate 5.5
    maximum bit rate 6.8
    Yet i am still getting the same problem?
    any ideas?
