Activity Forums Adobe InDesign Strange issue with SWF import file
  • Strange issue with SWF import file
    Posted by Nathan Alter on May 3, 2016 at 11:29 pm
    Hello!!
    I got a strange problem with Indesign CS5 upon SWF file import. I evaluate it strange cause it worked previously.
    Weeks ago when I tried to publish PDF file I tested how will look my SWF file (which I use for panorama images) the test PDF file worked OK. And while importing everything was normal, otherwise I would recognize.
    But then I messed with some other programs during weeks. And today while trying to do it again I see that in Media screen there is an issue – in some panoramas a controller (SKIN) embedded into SWF doesn’t show up in right place. And some SWF files doesn’t look right inside frame at all.
    I tried to restore system to previous date – on the date it should work, but the issue remains same mystically. What could cause this?
    Nathan Alter replied 10 years, 4 months ago 1 Member · 1 Reply
