Activity Forums Apple Final Cut Pro Legacy Strange interlacing?
  • Strange interlacing?
    Posted by Imry Halevi on November 9, 2009 at 5:34 pm
    I recently shot a video production, and recorded the feed using Wirecast.
    The recorded feed seems to have some strange interlacing problem.
    Clip: https://www.youtube.com/watch?v=4g_QssGVm0w
    It looks like strange horizontal lines, or a horizontal shift.
    The lines are much thicker than usual interlacing.
    I tried fixing the footage using a de-interlacing filter in FCP. But it didn’t change anything.
    Does anyone know what caused these lines, and how I can get rid of them?
    Thanks.
    Imry
    Bouke Vahl replied 16 years, 10 months ago 4 Members · 4 Replies
  • Tom Brooks
    November 9, 2009 at 5:58 pm
    The “zipper” effect is often caused by reversed field order. Another way of describing the problem is that somewhere in the early production, recording, or post-production phase, interlaced fields were not properly treated. Where in your production chain could this occur? If it happened at the event and is recorded that way, there may be nothing you can do to help it.
  • Max Christensen
    November 9, 2009 at 11:55 pm
    That’s wierd-
    Tryed SHIFT-fields?
  • Imry Halevi
    November 10, 2009 at 1:28 am
    Yeah. I tried field shift, and I tried applying a de-interlace filter.
    They did not change anything.
    I am not sure that this was a camera problem, because I recorded the feed in several different methods. Only a recording through a “Wirecast” software showed this problem.
  • Bouke Vahl
    November 10, 2009 at 9:37 am
    What i see is video scaled without de-interlacing, and without software that knows the source was interlaced.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
