Activity Forums Adobe After Effects Strange halo on border on transparent swf !
  • Strange halo on border on transparent swf !
    Posted by Tobbe Bergman on November 20, 2007 at 1:25 am
    Hi there I have been working with After Effects for a couple of weeks now so I guess you can say im a beginner.
    I am trying to do a morph between two images with RE:Flex.
    As I understand it this is the method to use for creating really cool interfaces like the ones on this site https://www.derbauer.de/index1.htmlor thishttps://www.carpe-diem-studios.de
    Can anyone explain why I get a brown halo or stroke on the transparent border of the exported swf?
    I managed to remove it but then I found out that I’ve lost the transparency and got a black background instead.
    All help will be greatly appreciated.
    Thank you!
    My little experimental morph looks like this:
    https://www.studiobergman.com/ae03.html
    Tobbe Bergman replied 18 years, 9 months ago 2 Members · 10 Replies
  • 10 Replies
  • Pierre Jasmin
    November 20, 2007 at 2:51 am
    Looks good except you say there should not be a brown outline
    Do you see that in AE or only when you export the SWF?
    I don’t think that this is introduced by RE:Flex
    IF you see this in AE THEN:
    I am not 100% on your source pictures are generated (are you making the source images in AE or importing that),
    if you apply AE Matte | Simple Choker over and under 0.0
    Does the outline go away in one case and does it grow in the other case.
    Pierre
  • Tobbe Bergman
    November 20, 2007 at 10:28 am
    Hi Pierre and thanks a million for your fast reply!
    It looks perfect in AE but not in the exported swf.
    I made the images in Photoshop and saved as png24 and have also tried with tiff and png8.
    I managed to lose the brown border with the Keylight effect but at the same time the transparence was replaced with black!
    This is driving me nuts!
    I will try the simple choker later today.
    Thanks again Pierre.
  • Tobbe Bergman
    November 20, 2007 at 9:13 pm
    Pierre
    Now I have tried the Simple Choker.
    A value of around +5 seems to work best.
    I also did one with AE’s solids (green thing) and that shows clearly brown stuff on the edges?
    https://www.studiobergman.com/ae04.html
    Thank you!
  • Pierre Jasmin
    November 20, 2007 at 9:20 pm
    Wonder where that brown stuff comes from?
    Is your comp background color brown (try black)
    Looks like a bug in the swf export related to premultiply, unmultiply if you ask me
    If you send me a project to techsupport@revisionfx.com I can look at it and submit the bug to Adobe if you like
    Pierre
  • Tobbe Bergman
    November 20, 2007 at 11:55 pm
    The background ‘is’ black and I tried to use only solids with some animated opacity and when you set it lower than 100% the brown appears? So its clearly not coming from ReFlex.
    Ill send it to you so you can have a look at it.
    If you look at the swf, it stops at opacity 50% where you can clearly see the brown!
    It looks as if the background indeed was brown but it is not.
    I just really hope I’ve missed something basic that you may have overlooked so I can get down and get creative instead of just trying to find out whats going wrong.
  • Pierre Jasmin
    November 21, 2007 at 5:14 am
    Thanks for sending project
    The brown seems to come from the shape stroke color even if it’s set to size 0
    Maybe it helps if you set stroke transparency to 0%?
    Pierre
  • Tobbe Bergman
    November 21, 2007 at 9:06 am
    If you export the project to swf do you also get the same “brown” result?
    I havent experimented with stroke transparency, where is that control? (Im at work at the moment)
    Could it be my graphic card that generate the brown when rendering the swf?
  • Pierre Jasmin
    November 21, 2007 at 5:35 pm
    I see that brown color in the Stroke Controls if you twirl up Ellipse – that’s all I see for now as where that could be coming from
  • Pierre Jasmin
    November 21, 2007 at 6:26 pm
    It’s not that, I see if I render that it blends to brown whatever the setup when you have transparency.
    I sent your test project to ae bugs to see what they say
    Pierre
  • Tobbe Bergman
    November 22, 2007 at 9:51 am
    Pierre
    Well it feels good to hear that im not the only one on the planet who have this issue.
    Lets hope they can fix this bug soon so that I can get creative and forget about the brown stroke thing.
    Thanks Pierre You’ve made my day!
