Activity Forums VEGAS Pro Strange halo effects when playback on HDTV
  • Strange halo effects when playback on HDTV
    Posted by Dag Halvorsen on April 13, 2012 at 11:31 pm
    Hi guys!
    I really need your help, with a very frustrating problem. I shoot with XDCAM EX1R, format 1080p/25. I edit in Vegas Pro, which renders two files: m2v video file and ac3 audio file (5.1ch). I import them into DVD Architect, which says “no rerendering necessary”.
    I’ve taken a couple of photos, to illustrate my problem.
    First photo is of my movie shown on the computer screen (preview in Vegas)::
    https://docs.google.com/open?id=0B2LZ75_4uCUQLS1ZcVNBam9XTGM
    There is no aliasing problem (the moire comes from the bad cell phone camera…).
    The second photo is of the same snapshot from my movie, shown on a TV set (FullHD Sony TV):
    https://docs.google.com/open?id=0B2LZ75_4uCUQZnFtNVZ4VXA2MFU
    There are obvious aliasing problems, as I understand it. Around the wires, you can see a major glare / halo effect, and moving objects with many details (or when panning high detail scenes), the details “vibrate”/flicker a lot!
    The movie was shot in 1080p/25. Vegas project settings:
    https://docs.google.com/open?id=0B2LZ75_4uCUQRHo5eGlBYVF5aGM
    Rendering settings:
    https://docs.google.com/open?id=0B2LZ75_4uCUQdEN0OXJGWEx0aVk
    I have tried rendering as progressive (which I usually do), but no difference.
    Since this is a MPEG2-file from Vegas (Main Concept plug-in), it is not possible to include a multi channel (5.1) audio file, so the 5.1 AC3 audio file must be rendered separately, and the two files merged in DVD Architect, which always outputs interlaced video format (I assume?). Here is where the problem occurs, or what do you guys think?
    Rendering a MP4 file in Vegas, is also no option, since a multichannel audio file cannot be included. Right?
    If I play the movie on the computer (Windows mediaplayer), using two screens: 1) PC monitor, and 2) TV (HDMI connected), the PC monitor displays the movie without any artifacts at all, whereas the TV shows this “halo effect”, no matter how I adjust the TV (FullHD TV).
    The difference I can think of, being the fact that the PC monitor can display 1080p, whereas the TV can only display 1080i… Am I right? Where is the interlacing done? In the display card or in the TV?
    I thought f.ex. BBC broadcasted 1080p on satellite, and there is no artifacts at all watching those HD channels. Maybe the computer display card (and media player) outputs only interlaced to TV screens? Why? I’m really not sure they do that…
    Moreover, since the DVD architect packed this .m2v video file and .ac3 audio file (both from vegas) into one iso file (the unpacked to one .m2ts file) and played back on media player/computer, maybe DVD architect outputs interlaced video, since the bly-ray standard has no 1080p/25 option? If so, why does this interlaced output display correctly on a PC monitor, and with halo effects and “vibrating/aliasing” effects on the TV?
    I am so satisfied with all other parts of my work flow, from shooting to editing, but when the end product displayed on TV suffers from quality issues, it’s extremely annoying…
    So, what should I do?
    Any help is highly appreciated!! 🙂
    BR Dag Halvorsen
    br Dag Halvorsen, Norway
    Nick White replied 14 years, 4 months ago 2 Members · 3 Replies
  • Nick White
    April 15, 2012 at 5:09 am
    No expert, except at finding trouble….so maybe I can start help. Bout time I paid a little back in:)
    My pet bugbear is 25p frame jitter, caused by refresh rate etc. I can’t watch many TV shows any more….so I know how it feels when you discover a fault in the process, and it really bugs you. Often I feel that most people do not notice this stuff
    My source is 1980 1020 p.
    Firstly, you say that the PC shows no artefacts. I can actually see a very faint halo around your post of the PC snapshot.
    Secondly, I know to my annoyance that HDMI – connected full HD TV shows those artefacts anyway, even on PC-generated text etc. It shows around areas of very high contrast. Most video gets away with it, but your source is particularly demanding.
    I also notice a fair bit of moire in the posted snapshots, but I am not sure if that is from the video, or jpeg compression when you took the snap. The frame size of the jpg is large and the file size small, so the moire could be that.If you reckon that the moire in the sky is caused by the snapshot settings, try to save the snapshot with a much higher jpg quality. Hope I am not throwing confusion in here…..
    I took some of my video, and rendered using your settings. There are a couple of light poles and trees up against the sky. They show a faint version of your problem, less because the contrast is not so great and the background lighter, which somewhat disguises the effect. I tried a Sony AVCHD render as well, with similar settings, and the halo is still there. This is all on my PC so far.I also did an x264 render with an external codec, and the same result.
    To simplify things, I left DVD Arch out of it, and simply played the files to my HDMI – connected TV, using only a USB thumb drive to transfer. The halos are there, in several different formats of render.
    So I have no solutions, have learned a couple of things, and AFAICS have at least simplified the problem a little.
    There is a tute somewhere on the Web about the BEST way to render in Vegas. IT involves using external rendering as well as internal.
    Having ranted on, and provided no more than more problems, I am now going to explore other renders, to see if this can be at least partially overcome.
  • Dag Halvorsen
    April 25, 2012 at 12:21 am
    The problem was finally solved!
    Thank you all for valuable info. I appreciate it very much.
    I must have overseen the sharpness control in the TV setup menu, or underesteimated it’s influence (can’t exactly remember).
    Anyhow, the sharpness setting was only at “10”, on a scale from 0 to 30. Turning it down to zero, solved the whole problem! This setting really caused lot’s of frustration, and I found it hard to believe that it was so powerful, and causing that many artifacts.
    The halo is always there, but now it’s extremely small, and at the same level as on the raw footage.
    I tried the AVCHD codec when rendering, and it works fine, also with 3/2 audio. However, with mp4 file format selected, Vegas crashed repeatedly, after 2-3 seconds.
    Now life is much easier 🙂
  • Nick White
    April 25, 2012 at 2:51 am
    Glad you got it sorted.
    BTW, I recently saw a youtube video about how to post the best video to YT. I feel that it actually gives very good results even for normal output. In fact I reckon it’s wasted on Youtube, which has a horrid system that seems to want to mangle whatever you give it! I believe they are trialling a new playback method that may help. Dunno….
    It involves importing a codec group into Vegas, using that to export to uncompressed video, then using Handbrake and another codec to do the final compressed result. It does give a nice output if you are willing to put in the time.
    Here is the tute
    https://www.youtube.com/watch?v=rWMX5lSvEgY
    The biggest problem is the HUGE intermediate file that comes out of Vegas to handbrake….GB/minute of film. As it’s only for transfer, storage is the main problem. Don’t even try to play it on most PCs.
    I take the requirement to set the project properties correctly with a pinch of salt, because as far as I can see this does not affect output or override the render settings, but only the editing experience.
    Also, for trials I passed over the Levels and stuff, until I worked out whether the exercise was worth it.
    Vegas has changed a bit, as far as I can see, from the way the tute shows. So rather than use their exact method, starting at 6:15 into the tute, instead of File Render or Make Movie, use Tools->Render to a New Track. That will give you the same GUI they show. It does create a separate file on HDD. Just make sure you ask to Open Folder when render is complete, or at least make sure you know the folder name.
    Also, at about 7:15 into the tute, they say it a bit wrong about Handbrake. The control shown is not in the General Tab any more, but a separate Output Files Tab.
    Hope that’s more use than nuisance! 🙂
    Nick
