Activity Forums Adobe After Effects Strange flicker/ghost on 3D text edges when 3D camera flies around
  • Strange flicker/ghost on 3D text edges when 3D camera flies around
    Posted by Gates Bradley on June 2, 2016 at 11:03 pm
    Hello. I’ve seen a couple of posts on here about this, but all were 6 years old or more, and seemed to deal with interlacing issues, which is not the case here, although this woman seemed to have my problem – https://forums.creativecow.net/thread/2/982608
    I’m an experienced AE user dealing with an issue I’ve never come across. I have some texts in 3D space that track to a camera pan. I used the 3D camera tracker for this. However, in RAW preview and in a render, there’s a weird flicker/ghosting, wherein it almost appears as if the text is strobing. There’s nothing to indicate this on any individual frame, and I’ve tried playback on 2 different monitors (though both running 60hz), with the same result. I’ve used this technique many times, but never have had this issue. I’ve posted a screen capture, with the text over video and then on black (to emphasize the flicker).
    I’m using AE CC 13.7.2 which is the latest addition as of the time of this writing. I have motion blur turned on for the text layers, as well as for the comp. I’ve tried messing with the comp shutter angle to no avail. Can anyone help? As of now the animation is really hard on the eyes and so not usable.
    Many thanks in advance.
    Gates Bradley replied 10 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
