Activity Forums Adobe After Effects Strange Flicker when slowing down Video
  • Strange Flicker when slowing down Video
    Posted by Ace Billet on August 9, 2005 at 8:14 am
    I have some DV footage (PAL) captured via FCP.
    When I try to slow down the footage in AE (Stretch 200%)
    I get a strange flicker in the background (the Pool)
    https://www.billet.co.il/webpics/Pool.jpg
    Is it because there is a lot of detail in the background ?
    Tests I did with a Sony Handycam looked fine, but this was shot on a PD150.
    I also tried slowing the video in Shake but I get the same result.
    And if I deinterlace the video I get an ugly, strobing motion.
    The guy is running around the pool, pretty fast motion.
    Ideas will be welcomed.
    cheers
    ace
    Michael Szalapski replied 21 years, 1 month ago 3 Members · 3 Replies
  • Michael Szalapski
    August 9, 2005 at 1:07 pm
    Have you tried applying frame blending to your layer?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Filip Vandueren
    August 10, 2005 at 3:36 am
    If it’s the horizontal lines in the tiles flickering, then its’ because they’re less than 1 pixel high, so they’re present on only 1 of the two fields.
    When you slow down, you see the two fields one by one,
    you might try setting ‘preserve edges’ in the interpret footage dialog, but that doesn’t always work that good.
  • Michael Szalapski
    August 10, 2005 at 11:12 am
    Also, do you have it set to best quality and full resolution?
    Sometimes I forget to tick those boxes then I smack myself in the forehead.
    – The Great Szalam
