Activity Forums Maxon Cinema 4D Strange fine line around object
  • Strange fine line around object
    Posted by Frank Ruggiero on November 23, 2011 at 3:44 pm
    Hi C4D Experts.
    This is the first time I am using the object buffer to give myself a little bit more control when I composite in After Effects. The issue I am having is that I am getting a fine line around my objects. The main render was edited with a straight fill, then in After Effects I ignored the alpha, but I still get a fine line around the objects. The mattes from the object buffer look rock solid. (It reminds me of After Effects when you try to key something with a premultiplied alpha and you get that line where you have aliasing at the ends of your fill.) Any ideas if there is a way to correct this without choking the matte?
    Thanks in advance.
    Frank R.
    Frank Ruggiero replied 14 years, 9 months ago 2 Members · 2 Replies
  • David Biederbeck
    November 25, 2011 at 7:22 pm
    try putting the original sequence below all your blocked out object buffers, this will fill in the gaps.
  • Frank Ruggiero
    December 1, 2011 at 7:35 pm
    Thank you David.
    That worked perfectly. I am not sure why it is an issue with the program. But your suggestion was a clever way to fix my problem.
    Frank
