Activity Forums Apple Final Cut Pro Legacy Strange FCP7 VO tool problem
  • Strange FCP7 VO tool problem
    Posted by Steve Dann on December 23, 2014 at 2:21 am
    Recently recorded a vo using the vo tool and the result sounded like it was speeded up and / or higher pitched. Anyone else had this? I didn’t have time to check it out but closed FCP and trashed preferences and it was ok for remainder of hour long edit. Have been running with currenty configuration for some time, no recent changes, this is new and scary.
    FCP7.0.3 on 3GHz Macbook Pro, 4GB RAM on Yosemite (hope that’s not the reason)
    Steve Dann replied 8 years, 11 months ago 3 Members · 6 Replies
  • Ann Clark
    December 23, 2014 at 11:40 pm
    I’m curious how FCP7 runs for you on Yosemite. Are you also using Motion? 4 GB of memory sounds kind of small for FCP7, IMHO.
    I don’t doubt Dave’s sage advice about translating audio to 48kHz, as it’s probably best to use the native sample rate. I’ve successfully used other sample rates, with rendering.
    If you used the FCP voiceover tool to capture the audio, it would seem very odd if FCP couldn’t play back its own recording.
    Let everyone know if you see the issue again, or if your recording turns out to be something other than 48kHz.
  • Steve Dann
    December 24, 2014 at 12:59 am
    Thanks for input. Definitely using 48kHz audio and can’t provoke fault with 44.1 set in VO tool. Never had a problem with 4gb ram, I rarely do anything that needs rendering. Might wind back to 10.8 as a precaution though.
  • Steve Dann
    December 24, 2014 at 8:47 am
    FCP seems fine on Yosemite with 4GB RAM Didn’t think FCP addressed more than 2.5GB anyway and I rarely do stuff with lots of rendering. Of course this problem may be the first indication it’s not … and this us why I have a backup Mac book running 10.8 …
  • Steve Dann
    December 26, 2014 at 8:22 pm
    Hi Dave, Thanks once again for the ideas. I’ve decided that Yosemite is an unknown and therefore risky and reverted to !0.8 which I’ve used incident free for a couple of years.
    Trouble is I’m always editing to deadlines in the next few minutes so there’s never time to ponder and try one potential solution at a time, so I’m unlikely to find out exactly was the cause was assuming it doesn’t happen again of course. I’ve taken to trashing prefs and repairing permissions as preventative maintenance … we’ll see …..
    Thanks again
    Steve.
  • Andrew Johnstone
    October 21, 2017 at 10:27 am
    I have just had exactly this problem with FCP7 on Mac OS Sierra.
    We had a new temporary edit suite set up for a film I am working on in Bristol. When we cam to record the VO on a 1920/25 ProRes timeline, the audio (set to 48khz/16bit) played back at Mickey Mouse speed. Neither the editor nor the engineers at Auntie could work it out.
    I brought the project file home to continue rough cutting on my system – where I have never had this problem – and the VO issue replicated itself on my system, to the answer is that it was simply a bug in the project preferences.
    The solution I found was to set the VO tool to record at 44.1 khz (you can toggle this setting in the VO window in FCP7), record a test, render it, then reset the VO tool to record to 48khz. This fixed my problem…
    HTH
    Andy
    Andy Johnstone
    Wild Dog Limited
    film & multimedia production
    http://www.wilddogworld.com
  • Steve Dann
    October 21, 2017 at 12:18 pm
    My solution was to reselect input even if its already selected and then never close vo tool. Minimising is fine, closing will require input to be reselected.
