Activity Forums Adobe After Effects Strange Faulty Render
  • Strange Faulty Render
    Posted by Jerry Renes on October 1, 2008 at 6:58 am
    Hi!
    I hope you guys can help me out a bit!
    I have a big After Effects project with around 35 Full HD compositions in it. I wanted to render all of these compositions at once and I made a watch folder render package and tried to render out the comps on a Mac Pro, 8 core, 8 gb of ram. Each composition has two render outputs, a low-res version and a Full HD version. The project was first created on a windows computer. Each composition has HDV footage in it.
    So here’s the problem: Some of my renders seem to have a 0,5 second piece of the composition (which doesn’t belong there) at the beginning of the rendered comp.
    I checked all of the compositions and they don’t have those pieces at the beginning when they’re in After Effects.
    I think this has something to do with the available memory after rendering some compositions….. Could this have something to do with the max ram cache size?
    But why put a wrong piece of the composition at the beginning of the render????
    I hope there is a solution because rendering out every composition by hand isn’t really an option because the whole project has around 120 compositions.
    Thanks for helping!
    Mark replied 17 years, 11 months ago 2 Members · 1 Reply
  • Mark
    October 1, 2008 at 2:27 pm
    Could you not split the render queues into a few projects and then render out each project…I have found that I have had issues in the past when trying to render upwards of around 25 items in one render queue.
    Regards
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
