Activity › Forums › Adobe Premiere Pro › Strange export effect with interlacing.
  • Strange export effect with interlacing.
    Posted by Alex Dowie on March 2, 2015 at 12:36 pm
    I am trying to export a video project that is to be broadcast on TV. The TV channel have asked for this to be exported with the field order Upper First, however whenever I export using this setting I get a strange forking effect all over the image. When i render the video out in progressive it is fine however.
    Has anybody experienced this or know how to fix this so it is exportable with the field order as Upper First?
    Thanks.
    Roger Averdahl replied 11 years, 6 months ago 5 Members · 5 Replies
  • Gary Milligan
    March 2, 2015 at 3:08 pm
    If you’re viewing your export on your computer monitor, it’s normal and expected to see the interlacing as you describe. View your export on a regular TV and all should be good.
    HTH
    Gary
  • Alex Dowie
    March 2, 2015 at 3:33 pm
    Hi Gary,
    Thanks for replying, i tested the rendered file out on a tv and i still get the same effect, I’ve attached an image to my original post showing the distortion.
  • Tero Ahlfors
    March 2, 2015 at 4:37 pm
    Check the footage on a proper reference monitor.
  • Shane Ross
    March 2, 2015 at 5:35 pm
    How are you getting this onto the TV? If you send a signal out of the computer via HDMI, or DVI…to a TV, you are sending out a COMPUTER DISPLAY signal, and computer display signals don’t show interlacing properly. In order to see things proper on a TV, you need a video IO device…AJA, Blackmagic Design, Matrox…you need one of their boxes connected to the computer, and then that out to the TV.
    Shane
    Little Frog Post
  • Roger Averdahl
    March 2, 2015 at 6:43 pm
    Your Sequence Settings are Lower Field First and you are exporting to Upper Field First, so the issues you are seeing are to be expected.
    I don’t know anything about you source footage but juding it from the image you posted it looks like the actual source footage is Upper Field First as well. What are the properties of your source footage? (Select a clip in the Project panel and you will see either LFF or UFF or p.)
