Activity › Forums › Apple Final Cut Pro Legacy › strange error message
  • strange error message
    Posted by Marc Poirier on June 5, 2005 at 7:10 pm
    I have a powerbook g4, 17in, 1 gig ram, 128 megs Vide Card, an external FireWire laCie drive. I’m trying to capture my project (I’m not new to this), but I get a message from the capture window “Could not open Handler. System memory is probably very low.”
    any clues on what that could be…With one gig of ram and no other apps running, I’d figure is more than enought to batch capture!
    thanks,
    Markyyy
    Jerry Hofmann replied 21 years, 4 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 5, 2005 at 9:03 pm
    Not had to trouble shoot this, but possibly just a restart might help. Take a look at the activity monitor app found in your utitlites folder in the apps folder. See what’s going on with the RAM… might give you a clue as to what is going on.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
