Activity Forums Adobe Premiere Pro strange duplication of files, anyone else?
  • strange duplication of files, anyone else?
    Posted by Kent Beeson on January 22, 2015 at 4:00 pm
    Something strange is happening when my producer shoots with his canon C100 and we then import files into latest PP CC – the interview files (only those) automatically duplicate even on the external hard drive they’re sitting on
    I ingest these into either Premier Pro or Prelude. When I do this the interviews are replicated up to eight times — exact duplicates of the one file I have on the source card and the hard drive. Sometimes an interview will make three copies, or six or eight. It seems the longer the interview the more copies.
    AND it only happens on interviews, which may have something to do with the length because they tend to be longer continuous takes. Each copy is an exact duplicate except the time code on all the copies starts at 00:00:00 where as the original starts wherever I left off after the last shot on the card.
    What’s the dealio?
    Kevin Monahan replied 11 years, 8 months ago 4 Members · 5 Replies
  • Tero Ahlfors
    January 22, 2015 at 4:33 pm
    I guess those are spanned clips and you aren’t using the media browser tab to import them?
  • Kent Beeson
    January 22, 2015 at 4:37 pm
    No actually they’re not spanned clips – but I do usually right click in my project window and select “import” – is this a problem? And if it is a problem, why, and why would it duplicate so many times as well?
    Is this an AVCHD issue with PP CC?
  • Tero Ahlfors
    January 22, 2015 at 4:39 pm
    Try importing the footage through the media browser.
  • Eric Mueller
    January 22, 2015 at 7:04 pm
    Happens to me as well – C100
  • Kevin Monahan
    January 23, 2015 at 10:58 pm
    Hi Kent,
    [Kent Beeson] “but I do usually right click in my project window and select “import” – is this a problem?”
    Yes, it could introduce issues like this.
    To avoid these problems, make sure that the entire card from the camera is copied to your media drive, then, import the files using the Media Browser and not File > Import or by dragging.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
