Activity Forums Adobe After Effects Strange duIK Behavior
  • Strange duIK Behavior
    Posted by Gabriel Bucataru on April 20, 2012 at 1:27 am
    Hi All –
    Not sure what I am doing wrong, but just following FAMOS’s tutorial using duIK on puppet tool, and for some reason when I add a bone to correspond to a certain puppet tool pin, the bone location is offset at the upper left corner of my precomp as if there’s no relative to the layer measurement.
    I imported my Illustrator file as a composition with layer size dimensions. Screenshot here:
    I am using AE CS5 on a mac with the latest duIK.any clues what I might be doing wrong?
    thanks a lot,
    gabi
    Gabi Bucataru replied 13 years, 10 months ago 4 Members · 3 Replies
  • Dale Kutzera
    June 16, 2012 at 12:56 am
    the same thing happens to me. Did you ever find a solution?
  • Grim Roper
    September 23, 2012 at 2:46 pm
    Have you seen Stuart Amos’ post in this forum?
    https://forums.creativecow.net/thread/2/967107#971057
    I was having exactly the exact same problem as you, and the answer for me was that you can’t manipulate any of the layer’s transform properties before pre-composing and/or applying the script.
    If you have to manipulate the transform properties, try checking “Move all attributes into new composition” when you pre-compose. It will be a little bit funky to work with big pre-comps for little things like legs, but it seems to allow the script to do it’s work.
  • Gabi Bucataru
    October 8, 2012 at 4:00 pm
    Hi Grim!
    Thanks so much for the reply! Sorry for my delay. Yes!! That takes care of the issue! I hope he will take care of this in future releases – it’s such a cool script!
    cheers,
    gabi
