Activity Forums Adobe After Effects Strange DPX issue in AE CS5.5
  • Todd Kopriva
    August 1, 2011 at 9:15 pm
    Max,
    I tried to respond to the bug report that you filed, but the email address that you gave doesn’t seem to work.
    I can open the file fine in Photoshop CS5.1 and Premiere Pro CS5.5, and in After Effects CS5 and CS4. Just not in After Effects CS5.5. That’s interesting.
    Please tell me as much as you can about where the file came from. (Thanks for including some of the specs in the test file image.)
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Max Link
    August 1, 2011 at 10:42 pm
    Hi Todd, thanks for looking into this.
    I don’t know why you can’t get email me, maybe try max@hs-unit.de instead.
    The DPXes originate from the capture software of a Weisscam HS-1. I don’t know what info might be relevant – anything pertinent to the files’ properties should be in the header, right?
    Best,
    Max
    Max Link
    DIT – Highspeed Technician
    München, Germany
  • Todd Kopriva
    August 1, 2011 at 11:02 pm
    I’ve added a link to this forum thread to the bug record in our database, so the engineer working on this will come to this thread for more details if needed.
  • Nathan Hackett
    November 28, 2011 at 7:30 pm
    Are the dpx’s from Nuke…
    I had the same problem and it was caused by having “fill” checked on my write node. Uncheck the box and you should be dandy
    n
    https://www.nhackett.com
  • Richard Edwards
    February 1, 2012 at 12:18 pm
    Did this ever get sorted out?
    I can’t open DPX files from a Sony F3 camera or from Lowry digital (they really know what they are doing).
    The files will open on every other program I can find, just not AE CS 5.5…
    Cheers Richard.
Page 2 of 2
