Activity › Forums › Apple Final Cut Pro Legacy › Strange crop when changing sequence setting
  • Strange crop when changing sequence setting
    Posted by Clara Rolls on November 12, 2009 at 2:47 am
    Hi all,
    I’ve never had this problem before and can’t find any posts relating to it.
    Basically, I have DVCPRO footage which creates an unrendered sequence if FCP automatically matches the settings, and when I get change it to become “rendered” (green lines along the timeline) the video becomes cropped.
    There are no motion attributes changed, FCP seems to be ignoring a large chunk of the frame…
    Here are the specifics:
    1. Started with r3d files, put into RedRushes using the only dvcpro preset listed (720p60)
    2. Ended up with movs that says dvcpro 720p60 960×720, but Quicktime says “Normal Size: 2048 x 1152”, which I believe is the usual 2k resolution?
    3. When allowing FCP to configure the sequence settings, it chooses:
    Compressor: DVCPRO HD 720p60
    Pixel Aspect Ratio: Square
    Frame Size: 2048 x 1152 (Custom 16:9) anamorphic off
    The video looks right, it has no distortion or scale BUT the timeline is all red and there are virtually no options in the playback pulldown menu.
    4. To get the timeline into green mode, I changed it to:
    Frame Size: 960 x 720 (HD(950×720) 16:9) anamorphic on
    The video still looks right ie. no squashing, though I had to scale it to 47%. But now there is a letterbox because the video is cropped to something even wider than 2:1.
    Any ideas?
    My plan is to continue editing today and set up RedRushes to output ProRes but it would be nice to continue with dvcpro as there are 20+ layers in the edit.
    Also, the colours are weird…very saturated and dramatic shifts in warmth. Not critical as grading will be done on raw files, but is that normal for dvcpro?
    Many thanks,
    Clara
    Bret Williams replied 16 years, 10 months ago 2 Members · 1 Reply
  • Bret Williams
    November 12, 2009 at 4:37 am
    The frame size is wrong. It should not be anything but 960x720z and it should not be anamorphic. Although it IS anamorphic, this is the standard DVCProHD 720p setting, and it’s normal pixel aspect. Anything else and you’ll have to render.
    Also, green lines indicate real time effects. Not a rendered segment of the timeline. You need to adjust your render settings to render everything, including real time.
    Of course there will be no rendering needed if you set up a DVCProHD 720p sequence and start editing.
