Activity Forums Apple Final Cut Pro Legacy Strange Compositing
  • Strange Compositing
    Posted by Dan Lachevre on July 26, 2006 at 10:40 am
    Have a weird problem with compositing modes. I’m using the ‘Screen’ compositing mode on V2 with another video layer underneath on V1. I have dissolves set in and out on the V2 layer which works fine until it is rendered. Once rendered the fades are ignored and it just cuts on.
    Any ideas? It’s strange it fades in & out fine until rendered.
    Cheers
    Danny
    Eli Mavros replied 20 years, 1 month ago 6 Members · 5 Replies
  • David Bogie
    July 26, 2006 at 3:53 pm
    You will need to precompose the V2 layer.
    bogiesan
  • Paul Dickin
    July 26, 2006 at 4:29 pm
    Hi
    Typing precompose into FCP’s online Help results in 0 occurrences…
    Typing “define precompose” into google I get this:
    Quote:
    [i]You can precompose a layer or multiple layers in After Effects. Pre-composing is often the answer to vexing nesting problems. Say you wanted to animate a car going down the road and show the wheels turning. You could first rotate the wheels on the car, then pre-compose the car and the wheels. Then you can move the nested comp (the car with the spinning wheels) down the road.
    To pre-compose layers, select the layers you want to pre-compose, (Command – select to pick layers that are not right next to each other) then choose pre-compose under the layer menu.[/i]
    How does that work in FCP?
  • Kevin Monahan
    July 26, 2006 at 6:32 pm
    Substitute the word “Nesting” – same deal.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Sebas
    July 26, 2006 at 9:59 pm
    did you try using opacity keyframes instead of transitions? that worked for me once but i’m not certain which fcp version it was.
    “pre-compose” is the term in afterfx, “nesting” in fcp.
  • Eli Mavros
    July 27, 2006 at 4:20 am
    You may have already done it, but often when this kind of thing happens to me, a trusty old preference trashing and quiting fcp does the trick…usually after a lot of head scratching.
    Best,
    Eli Mavros
