Activity › Forums › Apple Final Cut Pro › Strange colors in FCP X
Posted by Javier Sanchez on October 7, 2012 at 7:42 pmWhat are those extrange colors like false noisy pink and yellow on highlights on viewer (i have set my Prj on 1080p30 go pro material)
And it’s like in some frames those false colors… no info found on web about this problem.I7 MacBook Pro 2,66 8gb
Javier Sanchez
Head Of Technology
Gama DigitalJavier Sanchez replied 13 years, 10 months ago 2 Members · 6 Replies -
Javier Sanchez
October 10, 2012 at 8:20 pm -
Jeremy Garchow
October 10, 2012 at 8:27 pmIt looks like some sort of solarization in clipped highlights.
If you look at the footage in Quicktime, does the problem persist?
If you open the scopes, what does the waveform show for those areas?
Javier Sanchez
October 11, 2012 at 2:15 amthats the weird think it’s not on the vectorscope or parade neither on the renders. Even if i go one frame on and then go back it’s no constant. is like this frame yes, this frame no, this frame was but now no… and on play is like solarization disco party…
Javier Sanchez
Head Of Technology
Gama Digital -
Jeremy Garchow
October 11, 2012 at 2:18 am[Javier Sanchez] “and on play is like solarization disco party…
“Well, it could be worse I guess? I’ve been to worse parties I’m sure.
By any chance are your monitors extended? What’s your setup like?
Javier Sanchez
October 11, 2012 at 6:30 pm🙂 it’s directly on the main monitor of the MacBook Pro mid2010 2,66ghz i7 8ram.1440×900
I will have to return to FCP7 which is working fineJavier Sanchez
Head Of Technology
Gama Digital
