Activity › Forums › Apple Final Cut Pro Legacy › Strange colored shadows on signals through my DSR.11
  • Strange colored shadows on signals through my DSR.11
    Posted by Arnljot Bringedal on February 13, 2007 at 5:03 pm
    Hey:
    Hooked up my DSR-11 to a TV-set ( CRT )
    Used the yellow out output – into yellow input on the CRT.
    The picture gradually shows a yellow (gradient looking ) area on the left side of the picture – and a blue on the other side.
    It gradually increases as I playback the
    DV tape.
    The miscoloring is NOT recorded on the tape – and also shows up on the Tv when i Forewire a signal from FCp – through the DSR.
    The DSR-11 is brand new. Tried on other CRTs – same problem…
    Took out the DSR form the loop and did the same through the SOny Cam – into the CRT. Looks fine….
    Ideas anyone?
    *** Norwegian videojournalist & Editor***
    David Smith replied 19 years, 7 months ago 4 Members · 5 Replies
  • Travis Ballstadt
    February 13, 2007 at 5:27 pm
    You’re using the lowest possible quality video connection out of your DSR11. Try the S-Video connection.
    travis ballstadt
    http://www.thrillcateditorial.com
  • Arnljot Bringedal
    February 13, 2007 at 5:33 pm
    Tried it… same thing….
  • Jerry Hofmann
    February 13, 2007 at 5:37 pm
    Since you’ve narrowed down the problem to the DSR, I’d suggest you have it looked at. Does it do this with all tapes? If so, the DSR has a problem… You are working in PAL? If so make sure the DSR’s switch in the back is set to PAL too.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Arnljot Bringedal
    February 13, 2007 at 6:43 pm
    Thanks Jerry.
    All my things end up broken.
    The DSR is set to PAL.
    If I feed signals via FCP – FIREWIRE – out to CRT – the problems still exist.
    So I dont even use a tape….
  • David Smith
    February 14, 2007 at 5:16 am
    Is the DSR-11 sitting on or next to the crt? Just a wild shot in the dark, but you seem to have done the basic troubleshooting.
