Activity Forums Adobe Premiere Pro Strange behaviour on a Premiere Pro 6 project
  • Strange behaviour on a Premiere Pro 6 project
    Posted by Paul Jones on April 11, 2013 at 6:37 pm
    Hello
    Im working on a Premiere Pro 6 project which was all running as normal yesterday.
    Today the project opens ok but 90% of the shots won’t play even though they are all on the timeline, they show up as black.
    Nothing has changed since I saved it last night.
    If I click on one of the shots that won’t play it says media pending, but no media is being loaded and you can leave it for ages and nothing happens.
    Yesterday I also did a project backup to another hard drive, when I open this the same problem is there.
    It’s also the same when I open it on another Mac.
    When I close the Premiere Pro it crashes.
    I’m thinking a shot or some shots have corrupted rather than the project file.
    Do I have to rebuild the project somehow? If so is there an easy way?
    Any help to sort this problem really appreciated.
    Tom Daigon replied 13 years, 4 months ago 2 Members · 6 Replies
  • Tom Daigon
    April 11, 2013 at 6:48 pm
    Did you let all the media be indexed before you started editing on the timeline?
    If so, create another timeline. Copy and paste the old one to the new one.
    It that doesn’t work, create a new project, import the old project into the new one.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Paul Jones
    April 11, 2013 at 7:04 pm
    Yes I wait for the shots to be indexed, which seems to stop I think.
    If I copy the sequence to a new one I just get the spinning beach ball.
    I’ll try your suggestion of creating a new project and importing the old one…is there a suggested way to do this ?
  • Tom Daigon
    April 11, 2013 at 7:09 pm
    Just create a new project. Then go to the import menu and select the old one. Sorry, I dont have PrP right in front of me at the moment.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Paul Jones
    April 11, 2013 at 8:43 pm
    I’ve just tried that quite a few times and it just crashes Premiere Pro every time.
    I even tried to import previous saved projects I made yesterday and still the same.
    Can’t really understand what’s happened here as the project was all perfect yesterday
  • Paul Jones
    April 11, 2013 at 8:59 pm
    To add to my last post, I tried importing sequences only…I have 15 sequences in the project.
    I’ve tried importing them one by one….I get up to sequence 7, anything above that makes it crash.
    It makes me think that a corrupt clip was added to the later sequences ?
    The trick is to find which one ???
  • Tom Daigon
    April 12, 2013 at 3:01 am
    Long shot here. If you know which clips you used in the first offending sequence, in a new sequence you could try loading them one by one and see if any wont play or cause a problem. Then delete that clip from your media drive.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
