Activity Forums Adobe Premiere Pro Strange Behavior Part 1
  • Strange Behavior Part 1
    Posted by Lou Williams on August 12, 2012 at 10:40 am
    About a week I ago I started noticing that when I started up Premiere Pro, the bin that was open when I saved and closed down the night before was not open when I started the project the next day. This is very large project with over 13,000 elements. It didn’t bother me at first because all else seem well and I would just open the bin again. This was not limited to any particular bin but to anyone I had open and closed with at the end of the day. Then yesterday things got scary. I just finished a rather lengthy audio edit in audition and exported the results back to Premiere which went smooth enough. I closed down for lunch. When I started back up premiere pro couldn’t find three audio files. When I looked on the hard drive, the audio elements in the folders were gone? I found them in three new folders marked “Unknown Artist”. Looking at the time of creation it appeared to have happened during the last session. That’s end of part 1, part 2 things become frightening.
    I am using Premiere Pro CS6 running on i7-3930K intel, NVIDIA Quadro 4000, 24GIGs RAM and 8GIG G-Tech RAID 0.
    Any thoughts?
    Lou Williams replied 14 years, 1 month ago 3 Members · 3 Replies
  • Gary Huff
    August 12, 2012 at 1:31 pm
    You might want to go ahead and post part 2 as well, because both might be tied into the same issue.
    That said, I’ve never experienced Premiere or Audition moving files around where I didn’t expect.
  • Alan Peil
    August 13, 2012 at 4:34 pm
    To fix the problem with your bins not staying open on restart:
    Make sure that WINDOW – WORKSPACE – IMPORT WORKSPACE FROM PROJECTS is checked in PPro. I’ve experienced this same problem and this is the only solution I’ve found.
    As far as your audio files getting moved into a folder called ‘Unknown Artist’, I am fairly certain it is either Windows Media Player or iTunes ‘organizing’ your music. Make sure you have any options that mention ‘manage my media library’ or similar turned off.
  • Lou Williams
    August 21, 2012 at 12:01 am
    Thanks for the tip — that fixed my work flow problem but the disappearing files is still a mystery.
