Activity Forums Adobe After Effects Strange behavior importing paths from Illustrator
  • Strange behavior importing paths from Illustrator
    Posted by Lucia Bastenhof on September 14, 2008 at 12:22 pm
    I like to import paths from Illustrator to AE, but I’m always facing the same problem : the paths made with the brush tool (and without outlines in Illustrator), when imported in AE become 2 different paths : one for the center (the right one) and another one for the outlines !
    Is this normal ? 🙂
    It’s not a big problem when you import just one path, but with a hundred paths, it’s just wasted time to delete all the unexpected ones.
    I could decompose the path into Illustrator, and then delete the ouline path created : that works, when imported into AE, I just receive the center path. But that’s just as long as in AE.
    So, would you know how to fix it ? Is there an option elsewhere I need to check ?
    Thanks for your help ! 🙂
    Lucia Bastenhof replied 18 years ago 1 Member · 0 Replies
  • 0 Replies
