Activity › Forums › Adobe After Effects › Strange Audio problem
  • Strange Audio problem
    Posted by Scott Bush on May 1, 2008 at 8:04 pm
    I’m having a very strange audio preview problem, that just started today. I know my timeline has audio – a music track, sfx track and several VO tracks. The audio is there – I can see the waveforms, the layers are on – when I command-drag in the timeline, I can hear it. But when I RAM preview OR audio only preview, I get nothing. Nothing on the level meters, nothing from the speakers. I need to hear my audio to time my animations, and simply cannot figure this out. I checked my audio hardware prefs and it is set to “system default in/out”; I checked the sound section of system prefs, and it is set to the proper output (although at the bottom of the list is an option that says Adobe After Effects – I’ve never noticed this before – but I can’t select it. If I try it just bounces back to selecting line out) – system sounds, sound in other apps and cmd-dragging all make sound I’ve rebooted, repaired permissions, even re-installed. Nothing.
    Quick update: if I render out a movie, audio is there.
    I’m on a 8-core Mac Pro, 3.0Ghz, 16GB Ram, AECS3 8.0.2, Leopard 10.5.2
    Thanks for any suggestions.
    scott
    Scott Bush replied 18 years, 5 months ago 3 Members · 6 Replies
  • Aharon Rabinowitz
    May 2, 2008 at 1:54 pm
    I am assuming you shut AE and your compouter down already, and restarted, right?.
    Set your audio setting back to where they were. Then, try this:
    Composition > Preview > Make sure “Audio” is checked.
    This is probably not the solution, but it’s worth a shot.
    Thanks.
    Aharon
    Aharon Rabinowitz
    Email: arabinowitz (AT) yahoo (DOT) com
    All Bets Are Off Productions, Inc.
    Creative Cow After Effect Podcast
    Internet Killed the Video Star: A Guide to Creating Video for the Web
  • Scott Bush
    May 2, 2008 at 2:43 pm
    Aahron, thanks for the response.
    Yeah I tried that stuff…
    The good news is that this seems to be isolated to one particular project, which probably not co-incidentally was one of the first I did with Automatic Duck — most likely I did something wrong or some of my audio tracks were screwy. But when I opened another project, and then started a new one, the audio issues were gone.
    Still a strange deal though.
    Scott
  • Scott Bush
    May 2, 2008 at 4:42 pm
    I think so – I explained everything I tried in the OP – ram preview, cmd-drag, audio preview (num pad period) etc… as I said, the only thing that worked was CMD-dragging and a full render – RAM Preview and audio-only preview were not working.
  • Scott Bush
    May 2, 2008 at 5:39 pm
    There wasn’t any compressed audio, however, several files were DV Streams (.dv) – maybe that had something to do with it? The edit and audio was done in Final Cut and I brought it over with Automatic Duck. In the end I just ended up exporting the final audio from FCP as an aiff and all was well – but I’d still like to get to the bottom of it in case it comes up again. Thanks for the help.
  • Daniel Castilho
    May 6, 2008 at 2:11 pm
    Hi everyone, this my first message here.
    I have problems with my audio in AE, but a litle different than that. My audio just work’s in preview’s modes, when I’m working in the project, i can’t hear anything.
    Someone can help me?
    In others adobe programs audio is good. It’s just a AE audio problem.
    Sorry my bad english, i’m just learning. I’m a brazilian guy!
    Bryce
  • Scott Bush
    May 6, 2008 at 2:39 pm
    Bryce,
    That is the way audio works in AE – ONLY in previews and renders. It is not an editing program, so it doesn’t work like one (audio and real-time playback when you press play or the spacebar).
    Again, audio is only supposed to work in previews, renders, or when you CMD(CTRL)-drag the CTI in the timeline.
