Activity Forums Adobe Premiere Pro Strange audio probem!
  • Strange audio probem!
    Posted by Red Letter on May 19, 2006 at 1:15 pm
    I have an audio problem where some clips on the timeline will play at a reduced level for a few seconds at the start before returning to normal level. However, if I then play the clips a second time the levels are fine all the way through. I have de-noise and dynamics filters applied. If I render the problem clips, they also render with the fault. Any ideas?
    Red Letter replied 20 years, 4 months ago 2 Members · 3 Replies
  • Red Letter
    May 19, 2006 at 2:07 pm
    An update on this one. I now know it is caused by the de-noiser, but I don’t understand why it only happens on first play and not on subsequent plays or why it renders out with the reduced level fault on it. Does anyone have a solution please?
  • Chip Hess
    May 19, 2006 at 11:29 pm
    I feel your pain!
    We are working on a 12-chapter video
    and experiencing the same problem.
    Thanks for the info on the filter,
    as we are using that extensively!
  • Red Letter
    May 20, 2006 at 1:59 pm
    well I’m glad I’ve headed you in the right direction! If you find out what the problem is and its cure, please post the answer.
