Activity Forums Avid Media Composer Strange Artifacting MC5
  • Strange Artifacting MC5
    Posted by Mark Carr on October 27, 2010 at 11:50 am
    Hi Everyone
    I was wondering if you could help me. I have recently upgraded to Avid MC5. I was mid way through editing an SD project ( the raw files were AVI that i converted to MOV for my mac.) Everything was fine with MC4 but since upgrading I have noticed a tone of artifacting on my footage ( particularly when there is alot of camera movement). The artifacting is not on the raw footage ( both AVI or MOV) and this problem also does not occur when I import the same footage into FCP does anybody have any ideas?? I am tearing my hair out .
    Any advice would be greatly appreciated
    P.s
    I am in full green mode and also my project setting have come straight from my last MC4 project that worked fine.
    Brendan Maghran replied 15 years, 10 months ago 3 Members · 5 Replies
  • Brendan Maghran
    October 27, 2010 at 6:28 pm
    How are you editing the footage? Via AMA or did you import/transcode? I’m not sure if that would make a difference or not but you may want to try transcoding a few clips if you haven’t already. And what kind of artifacting?
  • Mark Carr
    October 27, 2010 at 8:36 pm
    The footage is imported and transcoded as MXF. The artifacting is horizontal lines ( between 4-6 ) that flash up on the screen when there is any camera movement. The faster the worse it gets.
  • Gary Hazen
    October 27, 2010 at 9:24 pm
    It sounds like a problem with field order. What are Avid import settings for field order?
  • Mark Carr
    October 27, 2010 at 10:19 pm
    I have it set as bottom field first. However im I right in thinking that it is not possible to change the field order after import. I have already finished the full edit on MC4 with no problems. It only since the upgrade that this problem has started
  • Brendan Maghran
    October 28, 2010 at 12:31 am
    Well you could try deinterlacing in mpeg streamclip (free download) or compressor once you’ve exported.
