Activity Forums Apple Final Cut Pro Legacy Strange Artifacting Around Text Pict Files
  • Strange Artifacting Around Text Pict Files
    Posted by Ian Dillon on August 15, 2006 at 11:05 pm
    I am getting strange artifacting around my black text against white. I am editing at 10 bit 720×486 uncompressed and am using a pict file for text. The problem isn’t horrible, but slightly noticeable.
    Thanks in advance.
    IAn.
    Steve Drew replied 20 years ago 7 Members · 10 Replies
  • 10 Replies
  • David Roth weiss
    August 15, 2006 at 11:36 pm
    If you have moved the text card using the controls in the motion tab you will get some goofy artifacts after rendering when cutting on a 10-bit timeline.
    DRW
  • Kevin Monahan
    August 15, 2006 at 11:55 pm
    Also could be alpha channel interpretation.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Ian Dillon
    August 16, 2006 at 12:03 am
    I’m not using an Alpha Channel or moving anything. Just a white slate with black graphics.
  • Kevin Monahan
    August 16, 2006 at 12:07 am
    Check these things then:
    Is your file rendered at Full Quality? (Sequence > Render > Full (dark green bar) checked?
    Are you checking the rendered file on a NTSC monitor?
    Is your RT Pop up showing:
    Safe RT?
    Playback Video Quality > High?
    Playback Frame Rate > Full?
    Motion Tab > Distort > Reset X button?
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
  • Steve Regian
    August 16, 2006 at 2:01 am
    I run into this a lot as we use uncompressed 10bit quite often and end up with little green artifacts and other miscellaneous stuff just there. Applying a matte choker works for us and adding a couple of pixels of blur helps clean up the edges.
  • David Roth weiss
    August 16, 2006 at 2:42 am
    Yep, those little green things really bug me.
  • Chris Poisson
    August 16, 2006 at 3:33 pm
    Perhaps the green bits are a 10 bit anomoly. I use 8bit almost exclusively and have never seen them.
  • David Roth weiss
    August 16, 2006 at 5:48 pm
    It is a weirdness only found when using 10-bit.
  • Hugo Tabares
    August 16, 2006 at 7:20 pm
    On Sequence Settings…
    Video Processing Tab…
    Motion Filtering Quality set it to: FASTEST (linear)
    That should take care of it…
    VisionMedia/Digital Brain
  • Steve Drew
    September 19, 2006 at 5:22 am
    I capture in 10bit, have a 10bit sequence, but render in 8bit YUV.
    Why?
    Because this problem has been around ever since FCP ‘supported’ 10bit.
    The fact that it’s STILL a problem is frankly an embarrasment.
    I never render in 10bit within 10bit sequences because of this.
    The workarounds?
    Render in 8bit – sure, that works, but you don’t get quality 10bit grading/FX.
    Set your Motion Filtering quality to it’s worst setting (linear) – sure, that works, but if you have any digital moves, re-framing going on, looks like puss.
    I’m not flaming here – just really disappointed with the lack of commitment by Apple to solving this.
    I have reported the problem to them, as should you all, but it’s been what, 4 years now?
