Activity Forums Adobe After Effects Strange (and horrible) AE error: attempt to write out an internally damaged time stream
  • Strange (and horrible) AE error: attempt to write out an internally damaged time stream
    Posted by Paul Roper on August 26, 2011 at 11:11 pm
    I just got this error while trying to save a project. I tried saving in different places, on different (local / network) drives, but still got the same error:
    I eventually just quit, without saving. Despite AE being set to auto save every 15 minutes, it hadn’t bothered auto-saving since about 6 hours ago. Which is rather annoying to say the least, especially when I try to load the erroneous file but get an “After Effects error: missing data in file.” error. So, back to an older backup version I’d luckily saved about 45 minutes ago.
    I tried having a peek at the saved AE files in TextEdit, to see if there’s anything obviously wrong, but there’s nothing humanly readable in there.
    Rather annoyed,
    Paul
    Paul Roper replied 15 years ago 2 Members · 2 Replies
  • Ben G unguren
    August 27, 2011 at 2:18 am
    A quick search on mylenium’s AE Error database gave me two “time stream” errors, though it didn’t have any information on the exact error you’re encountering:
    https://aeerrors.myleniumstuff.de/?p=408
    https://aeerrors.myleniumstuff.de/?p=1067
    Based on what I see there, you may want to try disabling expressions, especially “value_at_time” and looping ( “loopOut()” ) expressions. The problem may also be related to “compound keyframes” like masks or hue/saturation (where multiple values are stored in a single keyframe).
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Paul Roper
    August 29, 2011 at 4:11 pm
    Thanks, Ben for that information.
    The only expressions I have in the whole project are some colours linked to each other (I have about 16 shape layers, each with the fill colour linked (via an expression created with the pick-whip) to one colour, so I can change them all at once – but not keyframed).
    The only keyframes are a few simple motion keyframes plus some opacity keyframes – no time stretch, freeze frames or time-based expressions.
    I think it was probably After Effects just ‘having a moment’.
    Thanks for those links to that AE error database – very useful!
    – Paul
