Activity Forums Adobe After Effects Strange anchor point “drift” of camera null
  • Strange anchor point “drift” of camera null
    Posted by David Fuchs on August 3, 2015 at 3:10 pm
    Doing some comps for storyboards, I noticed that some of my layers appeared misaligned—for example, the layer boundary for a text box was offset from the actual text. My camera control is a simple one-node attached to a 3D null. Under normal circumstances, that null should always stay in the exact center of the comp as you move it—and opening a new project and comp with identical settings to the one I’m working on produces the expected effect. But for whatever reason in my project’s comps, the further I move the object, the more it goes out of alignment, like you were slipping its anchor point. Illustrated below:
    https://i.imgur.com/MrSQsVB.jpg
    There’s no weird orientation or rotation parameters being applied before/after parenting the camera to the null. It only seems to be happening on certain comps; starting a fresh comp with exact same settings in either a new project or the existing one works fine, but removing everything except the camera and null in the original comp does nothing to fix the problem. Tried trashing prefs and restarting.
    I assume I’m just missing something really obvious, but I can’t figure out what that might be.
    Running CC 2015.0 on a Mac running 10.10.4.
    View post on imgur.com
    David Fuchs replied 11 years, 1 month ago 2 Members · 2 Replies
  • Walter Soyka
    August 3, 2015 at 6:47 pm
    Are the parented camera’s X and Y position values 0?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • David Fuchs
    August 3, 2015 at 7:33 pm
    Yep. 0,0,-1667 based on default camera.
