Activity Forums Apple Final Cut Pro Legacy Strange affects to video when adding third graphic
  • Strange affects to video when adding third graphic
    Posted by Tucker Quenette on August 21, 2010 at 7:14 pm
    working on an older version of FCP and when I add 2 graphics to my timeline, everything is fine, but a third graphic is causing my white highlights to blow out.
    Anyone have any ideas?
    T
    Tucker Quenette replied 16 years ago 3 Members · 3 Replies
  • John Pale
    August 21, 2010 at 9:42 pm
    Tell us what Easy Setup you are using, what codec your base video is and what format your graphics are…..tell us what version of FCP you are using
    So far you have given no useful info to diagnose the problem.
  • Matt Mcgregor
    August 22, 2010 at 9:53 pm
    Give this a try:
    Go to your sequence settings and click on the video processing tab. Make sure “Render in 8-bit YUV” is selected and “White” is selected for “Process Maximum White as:”
    Good Luck with that.
  • Tucker Quenette
    August 23, 2010 at 12:23 am
    That fixed it! Thanks!
    T
