Activity Forums Apple Final Cut Pro Legacy strange 32 fps import issue
  • strange 32 fps import issue
    Posted by Hector Berrebi on September 3, 2006 at 10:01 am
    hello FCP forum.
    been looking forward to ask my first question here…
    i am imporing a quicktime animation file exported from after effects on a PC. the quicktime was exported as 25 fps (was imported into AE from FCP at 25 fps as well)
    in the browser window on FCP, in the video rate colummn, the same file appears as 32 fps (!?)
    sequence settings are set to PAL.
    any other quicktime i import behaves normally.
    i re-exported a few seconds from AE forcing a frame rate on the animation compression (instead of current which is default), same result…
    why? does it have any influence? i am syncing a clip and it seams to affect the fine-sync even when i use compressor to convert it to DV PAL 25fps…
    any help would be deeply apreciated
    peace.
    sLow
    Hector Berrebi replied 20 years ago 1 Member · 2 Replies
  • Hector Berrebi
    September 5, 2006 at 10:34 am
    still stuck with this problem… anyone?
    slow
  • Hector Berrebi
    September 7, 2006 at 8:26 am
    i cannot find anything on 32 fps issues…
    still hoping someone here had experience with what i described.
    thanks.
    slow
