Activity Forums VEGAS Pro Straigh lines? Shift not work why?
  • Straigh lines? Shift not work why?
    Posted by Emil Niemi on August 22, 2010 at 2:00 pm
    In sony vegas 9 my shift button doesn’t work? Or do Sony Vegas don’t have the feature u can do straight lines?
    I’m on masking a white solid and when holding down shitf and press on the next thing, it don’t go straight, have always to type down numbers etc, this take friggin ages.
    How i do straight? How i get my shift to work? the keyboard isn’t broken cus i CAN write LiKe ThiIISiisISss with shift
    Theo Van laar replied 16 years, 1 month ago 3 Members · 2 Replies
  • Mike Kujbida
    August 22, 2010 at 2:42 pm
    Unfortunately that feature has never been added.
    What I do is zoom in as much as I can and make sure the line is straight.
    It’s that or typing in numbers which, as you found out, is very annoying.
  • Theo Van laar
    August 22, 2010 at 7:03 pm
    Depending on the shape you need for your mask, you might be able to get the results you want with the Cookie Cutter FX
    Theo
