StorNext, Fibrejet and Avid setup
We are setting up two rooms with Mac-based Avids (MC5) and attaching to a StorNext SAN to access ProRes422 files via AMA and are discussing whether or not FibreJet is necessary or not, and what the advantages/pitfalls would be either way. We would be sharing media between only these two systems. Some early tests showed that AMA linking to Prores 422 files worked well without FibreJet, but we are being told to use FibreJet to avoid problems down the road. I unfortunately am one of those “knows just enough to be dangerous” guys. I do understand that the Avid will not write ProRes files and so there will be normal media folders as well with DNxHD files involved. Possible to make a single volume that both rooms will access? or should they each have their own volume that they can read/write to and have read only access to the other rooms volume? The way I see FibreJet set up in other parts of the facility, is to have each room with it’s own assigned volume. A bit confused, quite possibly totally off base, and hoping to avoid troubles before they start.
–Jeff C.
