Activity Forums Adobe After Effects Expressions Storing Random Numbers to Variables to Calculate Percent of Change
  • Storing Random Numbers to Variables to Calculate Percent of Change
    Posted by Mike Phillips on October 7, 2019 at 3:01 pm
    I have a random number generator with a range from 800,000 to 900,000 linked to a text layer and it changes every second. I want to know is there a way of storing and holding previous values to a variable? Example: Lets say at second 1 the value of the text layer is 800,000 and on second 2 the value changes to 900,000. I want to store the first seconds value to a variable so I can calculate the percent of change.
    Mike Phillips replied 6 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 7, 2019 at 4:03 pm
    Expressions have no memory, so variables don’t survive from one frame to the next. As a workaround, by manipulating the random number seed, you can recalculate the previous random number and use that to get the difference between the current and previous values. Something like this:
    period = 1; // duration of each random number
    seed = Math.floor(time/period);
    seedRandom(seed,true);
    nCur = random (800000,900000);
    seedRandom(seed-1,true);
    nPrev = random (800000,900000);
    diff = nCur – nPrev
    Dan
  • Mike Phillips
    October 7, 2019 at 4:06 pm
    Thank you will give this a try.
