Storing imported audio files
Im in the process of setting up a new FCP system and I want to make sure I get my file structure set up properly. Right now I have a folder on my primary drive that is titled FCP projects (where I will store all info relating to the project) and I have a folder on my external raid titled Final Cut Pro Documents (This is where I will capture media). My question is if I import an audio file where should that file be stored permanently?..should it go to the project file or the documents file. Any input would be greatly appreciated.
