Activity › Forums › Apple Final Cut Pro › store xfade or effect filter under a key
Posted by Jurriaan Van der kamp on February 11, 2012 at 8:24 amIn fcp 7 ( pro) i could store a 3sec xfade under a key so i could apply this very quickly.
So,can you change the default audioxfade and store it someware and can you do the same with video/audio filters? so that you make a fovourite list from witch you can chose
Can you copy and paste an audio cross (please discribe how)
thanxMark Morache replied 14 years, 7 months ago 3 Members · 4 Replies -
Simon Ubsdell
February 11, 2012 at 10:05 amTo change the default transition duration go to Preferences/Editing.
The default length is .5 seconds (because FCPX is timecode agnostic).
There is currently no way to customize more than one “favourite” transition length as you used to be able to do.
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com -
Mark Morache
February 11, 2012 at 11:19 amHow about this Jurriaan…
Apply the default time, then use the timeline index to find your transitions (type diss in the search bar), select the ones you want to change, hover the cursor over the timeline to activate the selected transitions, hit cmd-d to set a new duration.
You can’t do that in FCP7.
FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can’t stop thinking about her.Mark Morache
Avid/Xpri/FCP7/FCX
Evening Magazine,Seattle, WA
https://fcpx.wordpress.com -
Simon Ubsdell
February 11, 2012 at 1:39 pm[Mark Morache] “Apply the default time, then use the timeline index to find your transitions (type diss in the search bar), select the ones you want to change, hover the cursor over the timeline to activate the selected transitions, hit cmd-d to set a new duration.”
Cool idea.
But favourites would still be a preferable route, wouldn’t they?
Simon Ubsdell
Mark Morache
February 11, 2012 at 5:02 pmYes indeed. I miss dragging an effect into the bin for use later.
And I miss the ability to copy and paste individual attributes onto clips.
It’s interesting that there are shortcuts I can assign for copying the color settings from the previous or second or third previous clips.
It’s also interesting that I can grab an effect in the properties window of a clip, and I can drag it around. It becomes a ghost image, but I can’t do anything with it. It won’t land anywhere.
I know that I can create a color preset and apply that to clips. Still not as easy.
I’m sure they’ll add those thing, but not one instant too soon for me.
Avid/Xpri/FCP7/FCX
