Activity › Forums › Compression Techniques › Store the extracted frame name in array when executed from within a C program
  • Store the extracted frame name in array when executed from within a C program
    Posted by Narain Kumar on February 19, 2013 at 10:53 am
    I’m using the following C code to execute ffmpeg from within a C program
    #include <stdio.h>
    #include <stdlib.h>
    int main()
    char *app = "D:\\ffmpeg\\bin\\ffmpeg.exe -i";
    char *input = " D:\\video.mpg";
    char *output = " D:\\frames\\image%d.jpg";
    char *param = " -r 10";
    char str[300];
    snprintf(str, sizeof str, "%s%s%s%s", app, input, param, output);
    // str contains "D:\ffmpeg\bin\ffmpeg.exe -i D:\video.mpg -r 10 D:\frames"\image%d.jpg
    system(str); // <-- working fine, frames are being extracted
    do something here to store each extracted frame in an array
    so that the array contains image1.jpg, image2.jpg, image3.jpg...and so on
    getch();
    return 0;
    Is there a way to store the filenames in an array as and when they are extracted?
    Reuben Martin replied 13 years, 7 months ago 2 Members · 1 Reply
  • Reuben Martin
    February 19, 2013 at 9:04 pm
    You will have a lot more control integrating the libraries from the project rather than trying to call ffmpeg directly.
