Activity › Forums › AJA Video Systems › Storage w/AJA IO HD
Gary Adcock
August 16, 2008 at 1:04 pm[Carson Maddocks] “firstly, you’re a legend”
Only in my own mind Carson….
“Just to clarify, are you specifically saying that the IO HD won’t work with a NAS? How about using a NAS as a stand alone external storage solution (on a separate machine for data wrangling with RED)”
this has nothing to do with the IoHD.
The Infrastructure of NAS and the protocols used are not fast enough for the highend work you are proposing to do here. You cannot treat a RED / Phantom workflow this lightly, there is just not enough bandwidth over ethernet to handle the data flow needed for 1080 even as prores. Nor would I want to suffer consistently moving 100 GB over an ethernet connection.
Secondly why would you want to carry “network attached storage” on location? thats the part I do not get- The NAS architecture was designed for low bandwidth collaboration not real time onset issues.
Look you asked someone in a closed cozy university environment about tools needed for OnSet production – if you were building a classroom the answer would be very very different.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD -
Bob Zelin
August 17, 2008 at 3:39 pmPlease remember that the Slot 34 buss speed is MUCH SLOWER than that of a product run in a tower (like Mac Pro). So a simple 5 drive eSATA product (build it yourself, or buy one from one of the companies that you mentioned) will NEVER get the speeds of over 200mb/sec on a MAC Book Pro with a Slot 34 eSATA adaptor. It ain’t the drives, it’s the MAC Book Pro.
No matter how you try, you just can’t do everyting with the MAC Book Pro. You have TONS of gear that you bring out on a Red or Phantom shoot. Adding the correct computer will just make your life easier.
Everybody has a cart – the audio guy is not lugging everything around on his shoulder – he has a CART. You need one to. With your MAC Pro and your drives.Bob Zelin
Carson Maddocks
August 27, 2008 at 7:04 amThanks for all your help re: this. All useful information and have decided against NAS as a storage solution. Having said that, would I be fine for a ProRes capture (via HD-SDI) onto a 2-bay eSATA external (using the ExpressCard24 slot)? I’m not looking to do intensive editing, mainly 4:2:2 ProRes capture.
So I’m thinking something like this for tapeless based digital aquisition: Camera out -> (HD-SDI) -> AJA ioHD -> (Firewire 800) -> MacBook Pro -> (eSATA) -> External RAID 1 storage.
Bob, I understand re: cart and have looked into it already. But I’m more interested on your comment regarding max speeds of 200MB/s – is this regarding using a NAS? I’ve seen coflicting info about the necessary speed specs of ProRes – anybody able to confirm anything? How long could I record onto a 2TB RAID 1 ext hdd?
Cheers,
Carson M
Sydney, Australia -
Bob Zelin
August 28, 2008 at 3:12 amCarson –
this is what you are going to do. You are going to go to http://www.aja.com right now, and download the AJA Data Rate Calculator. It’s easy, it runs on any PC or MAC. And it will tell you exactly how much speed, and how much storage you need for ANY resolution, and how much space is taken up for one hour of storage.ProRes422 is very efficient, and requires very little. So your MAC Book Pro going into a Cal Digit slot 34 adaptor into an eSATA array will absolutely work for this with ProRes422.
Your next post should either say “I could not find the AJA , or “this AJA calculator is fantastic !”.
https://www.aja.com/html/support_kona3_swd.html – scroll down the page to find it. It’s free !
Bob Zelin
Carson Maddocks
August 30, 2008 at 12:46 amBOB: “this AJA calculator is fantastic !” haha… thanks mate. I couldn’t find the prores preset in there? is it just 1080i 8 and 10 bit presets?
looking forward to building an eSATA raid array out of my expresscard 34 slot…
Bob Zelin
August 30, 2008 at 1:38 pmthis is another great chart, that I love –
https://www.dulcesystems.com/html/video_space.html
And Dulce Systems is a GREAT company.
Bob Zelin
Keith Morris
September 1, 2008 at 4:08 amI’m in the market for a new RAID too for my MacBook Pro. I’ve got every port filled right now, it’s totally Frankensteined together. Everything is 1TB drives–2 esatas, 1 firewire 800, 1 fw 400, both usb’s. I’ve been editing my feature piecemeal, section by section, but now I need to move things around in the edit and just want it all on one type of drive. (I’ve got everything double backed up and have 18TB.) any suggestions on RAIDs that would work with a laptop welcome. i need space for about 6 to 8TB of footage to have all the raw footage accessible. anyone?
thanks!
keith
https://gutterking.tv -
Bob Zelin
September 1, 2008 at 2:08 pmIf I were you, I would stop thinking about a RAID 5 array, and start thinking about buying a professional MAC, like a MAC Pro tower. THEN you can get any RAID 5 array you like.
If you have 18TB of storage, I assume you are not an amateur, or this is not a hobby for you.Bob Zelin
Keith Morris
September 1, 2008 at 7:44 pmcant afford a new tower right now… so what should i get to have 8 TB running smoothly on a laptop?
Keith Morris
September 1, 2008 at 7:47 pmActually, I might be able to buy a tower if “ALL IN” to make it work with my current drives its under $5000. Possible? Please send me all the specs for what I’ll need to edit this RED footage easily for that price and I’ll put your name in the credits. 🙂
