Activity › Forums › VEGAS Pro › storage problem
  • Frank Stevn
    May 23, 2011 at 12:13 am
    Roger I have had virus and Trojans problems using Nero, Avast, AVG, etc.
    I am using for 6 moths Microsoft Security Essentials (free) and Superantispayware ($20 https://www.superantispyware.com/index.html), and so far no problems at all.
  • Roger Martin
    May 23, 2011 at 12:30 am
    The version of AVAST I am using is the latest.
    It never had a root scan option before.
  • Frank Stevn
    May 23, 2011 at 1:16 am
    Does any body has a review on Drobo S RAID Storage?
  • Nigel O’neill
    May 23, 2011 at 3:42 am
    In theory you should be able to remove the (f)ailing disk from the array, replace it with one that is identical or larger in size and then regenerate the mirror. Just how to do this depends on the WD RAID utility. RTFM… .
    I had a bad run with WD disks, but it turned out to be my RAID controller on the motherboard was at fault. I ended up using Windows RAID instead (in software) and not only did the problems go away, but my system performance increased significantly.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Page 2 of 2
