Activity Forums Storage & Archiving Storage device power failure
  • Storage device power failure
    Posted by George Anderson on April 8, 2010 at 7:34 am
    I think this is the right forum for this. I have a 1.5TB drive that I purchased to be an eSata drive. However, I ended up needing the drive for another purpose before setting up my eSata card. I journaled the drive for Mac and I used the Firewire 800 port instead. I copied the necessary files I needed on to it. Later, while working with the drive, the power transformer suddenly went out. There’s a lot of new work on this drive and I’m sure that my data is still on it, but I cannot get the drive to spin up or the LED to light up anymore. How can I get to my data? Someone suggested to me cracking open the plastic case, removing the hard drive and sticking it directly in my Mac. If that is a good option, how do I do it? Or is there another option(s)?
    George Anderson replied 16 years, 4 months ago 3 Members · 6 Replies
  • Bob Zelin
    April 8, 2010 at 2:05 pm
    losing power to your drive while it is writing data is the #1 way to corrupt your drive. If it’s a normal eSATA drive, yes, it will just slide right into your MAC Pro computer – there are three spare slots, that require no special cabling that will accept a normal standard SATA drive.
    But you say that you have a 1.5 TB drive – only Seagate made these, and these are the worst drives ever made. They were notorious for failing (believe me, I have suffered personally).
    Once you get the drive into your MAC, if you can’t read it, run Alsoft Disk Warrior on it – if this does not recover your media, you are screwed. You can pay thousands for a data recovery service, but I am sure that you are not interested in doing that !
    Bob Zelin
  • George Anderson
    April 8, 2010 at 8:13 pm
    Thanks, Bob.
    It’s a Western Digital. I never set it up to be an eSata drive. Does that matter? So, I just break open the case and pull out the drive and stick it in the Mac? Ok. I’ll try that this evening when I return. Thanks for your help.
  • George Anderson
    April 9, 2010 at 7:00 pm
    Well, I must be doing something wrong although I’m hard pressed to understand what. It seems pretty straight forward to me. I put the drive in, booted up the computer, but I don’t see the drive. It’s a 1.5TB drive from Western Digital. Is it possible that because it’s 1.5TB that it just doesn’t fit?
  • Chad Brewer
    April 9, 2010 at 11:19 pm
    If you have the drive properly seated in the drive slot, go to to Applications->Utilities->Disk Utility. If you do not see the drive recognized there, like Bob said, you are probably screwed or need to take out a loan for advanced data recovery.
    Chad Brewer
    Senior Tape Operator/Engineer
    TeleVersions
  • Bob Zelin
    April 10, 2010 at 1:02 am
    chad is correct. If you put the SATA drive into your MAC (it just slides right in), and it’s seated
    correctly, and Disk Utility doesn’t see it – you have 2 choices –
    1) run Disk Warrior to try to recover your data
    2) hire a data recovery service (about $4000, and no, I am not joking)
    3) give up.
    Bob Zelin
  • George Anderson
    April 11, 2010 at 4:20 am
    Sweet!
    Thanks, for your help. I’m going to keep my fingers crossed and try again.
