Activity Forums Adobe After Effects Stopping the wiggle expression after a few second.
  • Stopping the wiggle expression after a few second.
    Posted by Ruo Zheng on May 17, 2019 at 9:08 pm
    Hey everyone,
    I just starting learning about expressions and currently, I’m trying to make a flicker-in effect for this logo.
    I have wiggle(100,100) in the Opacity property of the logo but I’m trying to stop the flicker after like 5 second into the animation.
    What code should I use? I’ve studied C# before so my first instinct is to make an if statement and turn the wiggle into false statement after a period of time. But since AE expression uses JS so it’s different (not to mention all the expression properties). Would an array be better for this?
    Gaurav Kumar replied 7 years, 3 months ago 4 Members · 3 Replies
  • Andy Zou
    May 17, 2019 at 9:41 pm
    Personally, I’d whip/tie the wiggle function to a Slider, then keyframe the slider from 100 to 0 when you want it. That way you can also “fade” the wiggle using keyframes and avoiding expressions.
  • Dan Ebberts
    May 18, 2019 at 6:20 pm
    This should work:
    time < 5 ? wiggle(100,100) : value
    Dan
  • Gaurav Kumar
    June 26, 2019 at 2:19 pm
    Dan Ebberts thanks i was looking for this expression it’s save my lots of time
