Activity Forums Apple Motion stopping the Play
  • stopping the Play
    Posted by Terry Maloney on September 8, 2017 at 2:25 am
    Hi, ????
    Many times I hit the spacebar to stop the playback; but playback keeps on going.
    Then when I click in the timeline area and push the spacebar, it will stop.
    I either do that or —-
    I have to push ” Command 7″ two times. Once to get turn off the view to timeline and then once to turn on timeline.
    Is this normal? Am I doing something wrong?
    Thank you.
    Terry
    Terry Maloney replied 8 years, 11 months ago 1 Member · 1 Reply
  • Terry Maloney
    September 9, 2017 at 5:06 am
    Hi ????
    For you viewers, I found out there are no preset shortcuts.
    But my work around is with yKey (formally iKey). Just create a short cut that hits command 7, pause, command 7, pause, & then spacebar. Put it all under one key command — possibly “command spacebar”.
    Cheers,
    Terry ????
